Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Carving / Engraving
Tungsten Carbide Cutter egg tip 3,2 mm (9911)
Carving / Engraving
See all variations
15 GBP
Carbon
Leather
Rubber
Drywall/Plasterboard
Brick
Brass
Soft Metal
Softwood
Ceramic
Hardwood
Hardened Steel
Stainless Steel
Cast iron
Plastic
Shank diameter
Working diameter
Accessory length
Package contents
Price
2615991132
3.2 mm
39.0 mm
1 piece
£14.50*
  • Small pine cone shaped bit, one of Dremel's toughest engraving/carving bits.
2615990132
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter square tip 3,2 mm (9901)
  • Cylindrical shaped bit, One of Dremel's toughest engraving/carving bits
26159901DM
3.2 mm
39.0 mm
1 piece
£19.00*
Tungsten Carbide Carving bit DREMEL® MAX (9901DM )
  • Flat-headed, cylindrical shaped Dremel Max Tungsten Carbide carving bit
2615990332
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter pointed tip 3,2 mm (9903)
  • Cylindrical shaped bit with round tip. One of Dremel's toughest engraving/carving bits.
26159903DM
3.2 mm
39.0 mm
1 piece
£19.00*
Tungsten Carbide Carving bit DREMEL® MAX (9903DM)
  • Cylindrical-shaped Dremel Max Tungsten Carbide carving bit with round tip
2615990532
3.2 mm
38.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter ball tip 3,2 mm (9905)
  • Ball shaped bit, one of Dremel's toughest engraving/carving bits.
2615991032
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter spear tip 3,2 mm (9910)
  • Cone shaped point bit, one of Dremel's toughest engraving/carving bits.
Shank diameter
Working diameter
3.2 mm
Accessory length
39.0 mm
Tungsten Carbide (C-2)
Shape
Cone
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
39.0 mm
Maximum RPM
30,000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364008681
2615991132
Dremel accessory 9911 tungsten Carbide Cutter egg tip 3,2 mm
Delivery details
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
15 GBP
