Carving / Engraving
Dremel (9911)
Tungsten Carbide Cutter egg tip 3,2 mm
Tungsten Carbide Cutter egg tip 3,2 mm Tungsten Carbide Cutter egg tip 3,2 mm Tungsten Carbide Cutter egg tip 3,2 mm
Small pine cone shaped bit, one of Dremel's toughest engraving/carving bits.
£12.50* RRP incl. VAT
Technical details for Tungsten Carbide Cutter egg tip 3,2 mm (9911)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Drywall/Plasterboard Drywall/Plasterboard
  • Brick Brick
  • Brass Brass
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Ceramic Ceramic
  • Hardwood Hardwood
  • Aluminium Aluminium
  • Cast iron Cast iron
  • Plastic Plastic
Technical specifications
Shank diameter
Working diameter
Accessory length
Tungsten Carbide (C-2)
Shape
Cone
Mandrel use
No Mandrel Needed
Height
Maximum RPM
30.000 1/min
Variations
Delivery details: Tungsten Carbide Cutter egg tip 3,2 mm (9911)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615991132
8710364008681
