Carving/Engraving/Routing
Tungsten Carbide Cutter pointed tip 3,2 mm (9903)
Tungsten Carbide Cutter pointed tip 3,2 mm Tungsten Carbide Cutter pointed tip 3,2 mm
Cylindrical shaped bit with round tip. One of Dremel's toughest engraving/carving bits.
£11.00* RRP incl. VAT
Technical details for Tungsten Carbide Cutter pointed tip 3,2 mm (9903)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Drywall/Plasterboard Drywall/Plasterboard
  • Brick Brick
  • Brass Brass
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Ceramic Ceramic
  • Hardwood Hardwood
  • Aluminium Aluminium
  • Cast iron Cast iron
  • Plastic Plastic
Technical specifications
Shank diameter
Working diameter
Accessory length
Height
Maximum RPM
30.000 1/min
Package Contents
1 piece
Variations
Delivery details: Tungsten Carbide Cutter pointed tip 3,2 mm (9903)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615990332
8710364008629
