Cleaning/polishing
Versa Corner Brush (PC369-1)
Versa Corner Brush
Versa Corner Brush
This Corner Brush easily cleans hard-to-reach places, corners and edges.
  • The Corner Brush has an ideal size to clean the hard-to-reach areas. Thanks to the hollow centre design you can easily clean corners and edges.
  • Use the Corner Brush on hard surfaces, like tiled walls/floors, granite countertops, plastic, fabrics and metal! Endless versatile cleaning from stoves, motorcycle metal spokes and more.
  • Ready to conquer the cleanup? Simply screw the corner brush onto your Dremel Versa and you’re good to go.
  • For both indoor and outdoor cleaning, both dry or wet with your liquid cleaning solution. The multipurpose brush tackles everyday cleaning jobs with ease.
  • The bristles of the Corner Brush are long-lasting and washable, allowing you to use it multiple times.
£9.00* RRP incl. VAT
From cleaning corners of tiled walls to cleaning the nooks & crannies of metal spokes, the corner brush is ideal for both dry and wet applications. With the hollow centre design, this brush can form a pointing cleaning surface to get into those hard-to-reach places to enable a deep clean. The re-usable and high-quality brush combined with your Dremel ® Versa allows you to do more cleaning in less time and with less effort!
Example of usage
Technical details for Versa Corner Brush (PC369-1)
Technical specifications
Working diameter
40,0 mm
Accessory length
50,0 mm
40,0 mm
Maximum RPM
2.200 1/min
Height
50,0 mm
Package Contents
1 piece
Suitable Dremel devices
2615P369JA
8710364082469
Delivery details: Versa Corner Brush (PC369-1)
1x PC369
2615P369JA
8710364082469
