Versa
Versa Detail Brush (PC370-2)
Versa
The Detail Brushes are for cleaning nooks, crannies and hard-to-reach areas.
  • The multipurpose Detail Brushes are perfect for reaching and cleaning those hard-to-reach and tough-to-clean spots, like tile grout, faucets, stoves and drains.
  • Thanks to the conical brush design cleaning nooks and crannies will be done with ease. Cover small flat surfaces with the flat-headed design brush.
  • Simply screw the extension onto your Dremel Versa and screw on the required Detail Brush. You’re good to go!
See all variations
14 GBP
From cleaning grout and crevices on tiled walls and floors to getting in those nooks and crannies while cleaning faucets. Included is 1 flat brush which cleans small flat surfaces and 1 conical brush which helps to target those hard-to-reach areas or corners, especially combined with the extension. Both brushes are usable in dry and wet applications making them suitable for a wide range of cleaning applications. Bring together these long-lasting Detail Brushes with the high rotation speed of your Dremel® Versa to tackle grime and dirt with ease.
Working diameter
Maximum RPM
Package contents
Price
2615P370JA
20.0 mm
2,200 1/min
1 piece
£13.50*
  • The Detail Brushes are for cleaning nooks, crannies and hard-to-reach areas.
2615P361JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Heavy Duty Pad (PC361) 3 pieces
  • With this cleaning pad say goodbye to stubborn stains and surface scratches
2615P362JA
63.5 mm
3 pieces
£13.50*
Versa Foam Pad (PC362) 3 pieces
  • The cleaning pad for gentle dirt, stain and scruff mark removal from hard surfaces
2615P363JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Non-Scratch Pad (PC363) 3 pieces
  • This multi-purpose cleaning pad tackles the toughest of cleaning tasks without scratching
2615P364JA
63.5 mm
2,200 1/min
1 piece
£13.50*
Versa Bristle Brush (PC364)
  • The ideal cleaning spin brush for the most aggressive clean-up tasks
2615P365JA
63.5 mm
2,200 1/min
1 piece
£13.50*
Versa Variety Pack (PC365)
  • This 3-in-1 variety pack offers all the essential Dremel Versa accessory pads in 1 package.
2615P366JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Polishing Pad (PC366-3) 3 pieces
  • Multipurpose Polishing Pad perfect for gently polishing metals, leather and more without leaving any scratches.
2615P367JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Kitchen Scour Pad (PC367-3) 3 pieces
  • The Kitchen Scour Pad is ideal for removing dirt and food residue from pots and pans and other surfaces.
2615P368JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Extreme Scour Pad (PC368-3) 3 pieces
  • The Extreme Scour Pad is perfect for cutting through and removing tough stuck-on messes.
2615P369JA
40.0 mm
2,200 1/min
1 piece
£13.50*
Versa Corner Brush (PC369-1)
  • This Corner Brush easily cleans hard-to-reach places, corners and edges.
2615P372JA
62.0 mm
2,200 1/min
1 piece
£13.50*
Versa Kitchen Brush (PC372-1)
  • The Kitchen Brush is perfect for delicate cleaning without scratches.
Working diameter
20.0 mm
Maximum RPM
2,200 1/min
Suitable Dremel devices
DREMEL® Versa (PC10-1/10)
8710364082476
2615P370JA
Dremel Versa accessory  Versa Detail Brush PC370-2
Delivery details
  • 2x P370
14 GBP
