Versa
Versa Extreme Scour Pad (PC368-3) 3 pieces
Versa
The Extreme Scour Pad is perfect for cutting through and removing tough stuck-on messes.
- The Extreme Scour pad is ideal for eliminating burnt-on food from cast iron pans and grates, removing rust and paint from metal, eradicating rust and discolouration from concrete and conquering mould/mildew on stone.
- Thanks to it’s Silicon Carbide surface, you can quickly cut through and remove tough messes allowing you to tackle jobs that normally require more elbow grease. Clean more with less effort.
- Usable in dry and wet applications, perfect for indoor and outdoor tough cleaning jobs.
Tackle the removal of burnt-on food on cast iron pans and remove rust or stock with ease with the Extreme Scour Pad. The cleaning pad made of Silicon Carbide lets you quickly cut through and remove tough stuck-on messes. Usable in both dry and wet applications, the pad is great for deep cleaning indoors and outdoors. Clean more with less effort, thanks to its large surface area and your Dremel® Versa’s high rotation speed minimizing time and effort spent on scrubbing tasks. *Not recommended for aluminium, stainless steel, copper, coated nonstick cookware, non-tempered glass or aquarium as it will scratch the surface.
- The Extreme Scour Pad is perfect for cutting through and removing tough stuck-on messes.
Versa Heavy Duty Pad (PC361) 3 pieces
- With this cleaning pad say goodbye to stubborn stains and surface scratches
Versa Foam Pad (PC362) 3 pieces
- The cleaning pad for gentle dirt, stain and scruff mark removal from hard surfaces
Versa Non-Scratch Pad (PC363) 3 pieces
- This multi-purpose cleaning pad tackles the toughest of cleaning tasks without scratching
Versa Bristle Brush (PC364)
- The ideal cleaning spin brush for the most aggressive clean-up tasks
Versa Variety Pack (PC365)
- This 3-in-1 variety pack offers all the essential Dremel Versa accessory pads in 1 package.
Versa Polishing Pad (PC366-3) 3 pieces
- Multipurpose Polishing Pad perfect for gently polishing metals, leather and more without leaving any scratches.
Versa Kitchen Scour Pad (PC367-3) 3 pieces
- The Kitchen Scour Pad is ideal for removing dirt and food residue from pots and pans and other surfaces.
Versa Corner Brush (PC369-1)
- This Corner Brush easily cleans hard-to-reach places, corners and edges.
Versa Detail Brush (PC370-2)
- The Detail Brushes are for cleaning nooks, crannies and hard-to-reach areas.
Versa Kitchen Brush (PC372-1)
- The Kitchen Brush is perfect for delicate cleaning without scratches.
Suitable Dremel devices
- 3x PC368
