Versa
Versa Kitchen Brush (PC372-1)
Versa
The Kitchen Brush is perfect for delicate cleaning without scratches.
  • The Kitchen Brush is perfect for delicate cleaning, quickly removing food stains without scratching the surface.
  • Tackle everyday tasks from cleaning most common mugs, glasses and bottles to scrubbing pots, pans and dishes. Clean more with less effort.
  • With it’s long Nylon bristles it’s easier to deep clean the inside of bottles or deep pots especially when combined with the extension (10cm), hard to reach places will be cleaned with ease.
14 GBP
The Dremel Versa Kitchen Brush quickly removes food stains without scratching the surface. With its long-lasting and washable nylon bristles, you can use the Kitchen Brush accessory for many cleaning jobs. Easily reach bottoms of glasses, bottles and mugs for thoroughly cleaning, thanks to the included extension (10cm). The front bristles expand into the bottom of bottles for effective cleaning of internal edges and cover hard-to-reach areas.
Working diameter
62.0 mm
Working height
100.0 mm
Max working depth
190.0 mm
Maximum RPM
2,200 1/min
Height
100.0 mm
Suitable Dremel devices
DREMEL® Versa (PC10-1/10)
8710364082483
2615P372JA
Dremel Versa accessory Versa Kitchen Brush PC372-1
14 GBP
