Versa
Versa Kitchen Scour Pad (PC367-3) 3 pieces
Versa
The Kitchen Scour Pad is ideal for removing dirt and food residue from pots and pans and other surfaces.
  • With its scrubbing power, the Kitchen Scour Pad is ideal for everyday cleaning to help remove residue and tough dirt in the kitchen.
  • Rise to the challenge with the Kitchen Scour Pad to remove burnt-on food residue on pots and pans along with scrubbing off dirt around stove burners, grates and oven racks.
  • Usable in dry and wet applications even in combination with the Splash Guard attachment, making it more versatile to tackle everyday cleaning in the kitchen.
See all variations
14 GBP
Perfect for cleaning cookware, stove burners & grates and oven racks. With its scrubbing power, deep cleaning dirty surfaces will be less of a problem for your everyday cleaning jobs. The waterproof and cordless Dremel© Versa cleaning tool combined with the Kitchen Scour Pad is ideal for dry and wet uses leaving your kitchen sparkling clean. With its circular shape, it fits easily around stove burners or even in small pots. Jobs will be completed in no time with the Dremel Versa’s high rotation speed allowing you to clean more with less effort. Simply start by placing the accessory on the backing pad of your cordless Dremel Versa tool. *Not recommended for aluminium, stainless steel, copper, coated nonstick cookware, non-tempered glass or aquarium as it will scratch the surface.
Working diameter
Maximum RPM
Package contents
Price
2615P367JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
  • The Kitchen Scour Pad is ideal for removing dirt and food residue from pots and pans and other surfaces.
2615P361JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Heavy Duty Pad (PC361) 3 pieces
  • With this cleaning pad say goodbye to stubborn stains and surface scratches
2615P362JA
63.5 mm
3 pieces
£13.50*
Versa Foam Pad (PC362) 3 pieces
  • The cleaning pad for gentle dirt, stain and scruff mark removal from hard surfaces
2615P363JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Non-Scratch Pad (PC363) 3 pieces
  • This multi-purpose cleaning pad tackles the toughest of cleaning tasks without scratching
2615P364JA
63.5 mm
2,200 1/min
1 piece
£13.50*
Versa Bristle Brush (PC364)
  • The ideal cleaning spin brush for the most aggressive clean-up tasks
2615P365JA
63.5 mm
2,200 1/min
1 piece
£13.50*
Versa Variety Pack (PC365)
  • This 3-in-1 variety pack offers all the essential Dremel Versa accessory pads in 1 package.
2615P366JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Polishing Pad (PC366-3) 3 pieces
  • Multipurpose Polishing Pad perfect for gently polishing metals, leather and more without leaving any scratches.
2615P368JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Extreme Scour Pad (PC368-3) 3 pieces
  • The Extreme Scour Pad is perfect for cutting through and removing tough stuck-on messes.
2615P369JA
40.0 mm
2,200 1/min
1 piece
£13.50*
Versa Corner Brush (PC369-1)
  • This Corner Brush easily cleans hard-to-reach places, corners and edges.
2615P370JA
20.0 mm
2,200 1/min
1 piece
£13.50*
Versa Detail Brush (PC370-2)
  • The Detail Brushes are for cleaning nooks, crannies and hard-to-reach areas.
2615P372JA
62.0 mm
2,200 1/min
1 piece
£13.50*
Versa Kitchen Brush (PC372-1)
  • The Kitchen Brush is perfect for delicate cleaning without scratches.
Working diameter
63.5 mm
63.5 mm
Maximum RPM
2,200 1/min
3
3
Suitable Dremel devices
DREMEL® Versa (PC10-1/10)
8710364082445
2615P367JA
Dremel Versa accessory  Versa Kitchen Scour Pad PC367-3
Delivery details
  • 3x PC367
14 GBP
