Cleaning/polishing
Versa Kitchen Scour Pad (PC367-3)
The Kitchen Scour Pad is ideal for removing dirt and food residue from pots and pans and other surfaces.
With its scrubbing power, the Kitchen Scour Pad is ideal for everyday cleaning to help remove residue and tough dirt in the kitchen.
Rise to the challenge with the Kitchen Scour Pad to remove burnt-on food residue on pots and pans along with scrubbing off dirt around stove burners, grates and oven racks.
Usable in dry and wet applications even in combination with the Splash Guard attachment, making it more versatile to tackle everyday cleaning in the kitchen.
Quick and easy installation by placing it on the backing pad of your Dremel Versa.
One Kitchen Scour Pad, many cleaning projects. The Kitchen Scour Pad is washable allowing it for multiple uses.
£9.00*
RRP incl. VAT
Perfect for cleaning cookware, stove burners & grates and oven racks. With its scrubbing power, deep cleaning dirty surfaces will be less of a problem for your everyday cleaning jobs. The waterproof and cordless Dremel© Versa cleaning tool combined with the Kitchen Scour Pad is ideal for dry and wet uses leaving your kitchen sparkling clean. With its circular shape, it fits easily around stove burners or even in small pots. Jobs will be completed in no time with the Dremel Versa’s high rotation speed allowing you to clean more with less effort. Simply start by placing the accessory on the backing pad of your cordless Dremel Versa tool. *Not recommended for aluminium, stainless steel, copper, coated nonstick cookware, non-tempered glass or aquarium as it will scratch the surface.
Example of usage
Technical details for Versa Kitchen Scour Pad (PC367-3)
Technical specifications
Working diameter
63,5 mm
63,5 mm
Maximum RPM
2.200 1/min
Package Contents
3 pieces
Suitable Dremel devices
2615P367JA
8710364082445
Delivery details: Versa Kitchen Scour Pad (PC367-3)
3x PC367
2615P367JA
8710364082445
8710364082445
