Cleaning/polishing
Versa Non-Scratch Pad (PC363)
This multi-purpose cleaning pad tackles the toughest of cleaning tasks without scratching
General purpose fibre scouring pad for tough jobs without scratching the surface
Ideal for kitchen equipment such as pots, pans, sinks, stoves and more
Quick and easy accessory change with the hook and loop system
Oversized accessories gets into tight spaces
£9.00*
RRP incl. VAT
Perfect for tackling surfaces that require scrubbing without scratching. The Dremel Versa Non-Scratch Pad is suitable for both indoor and outdoor use and is ideal for pots, pans, sinks and more. With its oversized surface area it fits easily into tight spaces. Combine the Dremel Versa’s high rotation speed scrubbing with the multi-purpose cleaning pad and the jobs will be completed in no time.
Example of usage
Technical details for Versa Non-Scratch Pad (PC363)
Technical specifications
Working diameter
63,5 mm
63,5 mm
Maximum RPM
2.200 1/min
Package Contents
3 pieces
Suitable Dremel devices
2615P363JA
8710364081684
