Versa
Versa Variety Pack (PC365)
Versa
This 3-in-1 variety pack offers all the essential Dremel Versa accessory pads in 1 package.
  • Whether you need a multi-purpose pad for hard non-porous surfaces or you need the more aggressive pad for rust and old paint removal; we've got you covered in the Dremel Versa variety pack. 3 different accessories for 3 different purposes.
See all variations
14 GBP
The Dremel Versa foam pad is the solution for a variety of cleaning tasks on a wide range of surfaces including counter tops, stoves, ovens, sinks, microwaves, regifrdators and more. The Dremel non-scratch pad is ideal for tough jobs that require scrubbing without scratching. The heavy duty pad can tackle stubborn dirt with ease, thanks to its micro-abbrasive surface; from burnt-on food in your oven to wears and tears on your garden furniture. Switch from tile to glass or textile to metal in no time. Use the accessories with or without water or cleaning solution depending on desired application.
Working diameter
Maximum RPM
Package contents
Price
2615P365JA
63.5 mm
2,200 1/min
1 piece
£13.50*
  • This 3-in-1 variety pack offers all the essential Dremel Versa accessory pads in 1 package.
2615P362JA
63.5 mm
3 pieces
£13.50*
Versa Foam Pad (PC362) 3 pieces
  • The cleaning pad for gentle dirt, stain and scruff mark removal from hard surfaces
2615P361JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Heavy Duty Pad (PC361) 3 pieces
  • With this cleaning pad say goodbye to stubborn stains and surface scratches
2615P363JA
63.5 mm
2,200 1/min
3 pieces
£13.50*
Versa Non-Scratch Pad (PC363) 3 pieces
  • This multi-purpose cleaning pad tackles the toughest of cleaning tasks without scratching
2615P364JA
63.5 mm
2,200 1/min
1 piece
£13.50*
Versa Bristle Brush (PC364)
  • The ideal cleaning spin brush for the most aggressive clean-up tasks
Working diameter
63.5 mm
63.5 mm
Maximum RPM
2,200 1/min
8710364081707
2615P365JA
Three different Versa cleaning pads
Delivery details
  • 1x Heavy duty pad (PC361)
  • 1x Foam pad (PC362)
  • 1x Non-scratch pad (PC363)
14 GBP
