Cleaning/polishing
Versa Variety Pack (PC365)
Versa Variety Pack
Versa Variety Pack
Versa Variety Pack
Versa Variety Pack
Versa Variety Pack Versa Variety Pack Versa Variety Pack Versa Variety Pack
This 3-in-1 variety pack offers all the essential Dremel Versa accessory pads in 1 package.
  • Whether you need a multi-purpose pad for hard non-porous surfaces or you need the more aggressive pad for rust and old paint removal; we've got you covered in the Dremel Versa variety pack. 3 different accessories for 3 different purposes.
£9.00* RRP incl. VAT
The Dremel Versa foam pad is the solution for a variety of cleaning tasks on a wide range of surfaces including counter tops, stoves, ovens, sinks, microwaves, regifrdators and more.
The Dremel non-scratch pad is ideal for tough jobs that require scrubbing without scratching.
The heavy duty pad can tackle stubborn dirt with ease, thanks to its micro-abbrasive surface; from burnt-on food in your oven to wears and tears on your garden furniture.
Switch from tile to glass or textile to metal in no time. Use the accessories with or without water or cleaning solution depending on desired application.
Technical details for Versa Variety Pack (PC365)
Technical specifications
Working diameter
63,5 mm
63,5 mm
Maximum RPM
2.200 1/min
Variations
Delivery details: Versa Variety Pack (PC365)
1x Heavy duty pad (PC361)
1x Foam pad (PC362)
1x Non-scratch pad (PC363)
2615P365JA
8710364081707
