Drilling
Wood Drill Bit Set (636) 4 pieces
Drilling
Set of 4 drill bits for drilling into wood
- Set of 4 dill bits with centering point for drilling into wood.
- Long lasting performance thanks to the titanium coating.
- Ideal for precision drilling in hard wood, soft wood, laminate, plywood and more.
13.8 GBP
Softwood
Hardwood
Fiberboard
Laminates
Plywood
Chipboard
What can you do with it?
The Dremel wood drill bit set contains 4 drill bits with centering point for drilling into wood. Ideal for precision drilling in hard wood, soft wood, laminate, plywood, chipboard and fiberboard. The titanium coating offers high performance and a longer lifetime. The different drilling diameters included are 3, 4, 5 and 6 mm.
How to use?
Pick the right size for your project. Use the tip of the drill bit to go into the material straight at a 90° angle.
Materials to use on
Suitable for use on wood and wood-like materials.
Recommended speed
Maximum RPM: 35.000
Shank diameter
Usage
Unique Dremel titanium wood drill bits with diameter 3, 4, 5 and 6 mm.
11.0 mm
38.0 mm
Height
64.0 mm
Maximum RPM
35,000 1/min
Working diameter
3.0, 4.0, 5.0, 6.0 mm
4
4
Suitable Dremel devices
Retired Products
Multi-Tools
8710364026289
26150636JA
Order number26150636JA
EAN Code8710364026289
Delivery details- 1x 3.0mm Wood drill bit 1x 4.0mm Wood drill bit 1x 5.0mm Wood drill bit 1x 6.0mm Wood drill bit
- Product box length, 1.7 cm
- Product box height, 13.5 cm
- Product box width, 6.7 cm
13.8 GBP
