Accessory Kits
Woodworking Set (681)
Accessory Kits
20 pieces Woodworking Accessory Set
- Start-up kit for DIY woodworking applications: carving, engraving, sanding and drilling
- Comes with reuseable storage case and 20 genuine Dremel accessories
- Can be used on both soft and hard wood
17.5 GBP
The high quality accessory kit includes an assortment of must-have accessories for creative DIY projects using wood. Craft your own hanging shelves, create decorative ornaments or personalise your wooden projects with an engraved design. With this kit you are covered for engraving, sanding and drilling applications on both soft or hard wood.
Package contents
Price
2615C681JA
1 piece
£17.50*
- 20 pieces Woodworking Accessory Set
Order number2615C681JA
EAN-Code8710364080731
2615S723JA
1 piece
£35.00*
100 pieces DREMEL® Multipurpose Accessory Set (723)
- Ideal Dremel starter kit with 100 accessories for various applications and materials
Order number2615S723JA
EAN-Code8710364072828
26150688JA
1 piece
£19.00*
Cutting Set (688)
- Set of 68 cutting accessories to cut in a variety of materials
Order number26150688JA
EAN-Code8710364029112
26150687JA
1 piece
£19.00*
Multipurpose Set (687)
- Set of accessories for cutting, carving, sanding, cleaning, polishing, grinding and sharpening
Order number26150687JA
EAN-Code8710364029105
26150684JA
1 piece
£19.00*
Cleaning / Polishing Set (684)
- Ideal starter set for cleaning and polishing including 20 accessories
Order number26150684JA
EAN-Code8710364029099
EAN Code8710364080731
Delivery details- 1x High Speed Cutter 3.2 mm (190)
- 1x High Speed Cutter (191)
- 1x High Speed Cutter 3.2 mm (194)
- 1x Sanding Band & Mandrel 13 mm grit 60 (407)
- 2x Sanding Band 13 mm 60 grit (408)
- 2x Sanding Band 13 mm 120 grit (432)
- 10x Sanding Disc (411)
- 1x Drill Bit (150)
- 1x Mandrel (402)
- Product box length, 8.5 cm
- Product box height, 14.5 cm
- Product box width, 4.5 cm
17.5 GBP
