Accessory Kits
Dremel (681)
20 pieces Woodworking Accessory Set
Start-up kit for DIY woodworking applications: carving, engraving, sanding and drilling
Comes with reuseable storage case and 20 genuine Dremel accessories
Can be used on both soft and hard wood
Compatible with all Dremel Multi-tools
£17.00*
RRP incl. VAT
The high quality accessory kit includes an assortment of must-have accessories for creative DIY projects using wood. Craft your own hanging shelves, create decorative ornaments or personalise your wooden projects with an engraved design. With this kit you are covered for engraving, sanding and drilling applications on both soft or hard wood.
Example of usage
Suitable Dremel devices
Multi-Tools
2615C681JA
8710364080731
Delivery details: Woodworking Set (681)
1x High Speed Cutter 3.2 mm (190)
1x High Speed Cutter (191)
1x High Speed Cutter 3.2 mm (194)
1x Sanding Band & Mandrel 13 mm grit 60 (407)
2x Sanding Band 13 mm 60 grit (408)
2x Sanding Band 13 mm 120 grit (432)
10x Sanding Disc (411)
1x Drill Bit (150)
1x Mandrel (402)
Product box length, 8.5 cm
Product box height, 14.5 cm
Product box width, 4.5 cm
2615C681JA
8710364080731
8710364080731
