Spazzola in acciaio inossidabile 13 mm (531-2) 2 Pz.
Pulitura / Lucidatura
Ideal for cleaning, deburring and surface-finishing items made from stainless steel, aluminum, silver, pewter or other white metals
  • It is very effective on flat surfaces and in hard-to-reach places, such as slots
  • Stainless steel wire bristles
  • Very effective on flat surfaces and in hard-to-reach places, such as slots
Vedi tutte le varianti
Tubi in metallo
Lamiera in acciaio
Ottone
Acciaio temprato
Oro
Alluminio
Argento
Acciaio inox
Ghisa
Rame
Stainless steel brushes do not cause after-rust when used on corrosive-resistant materials like pewter, aluminum and stainless steel. Ideal for cleaning, deburring and surface-finishing. Very effective on flat surfaces and in hard-to-reach places, such as slots. Pack includes two stainless steel brush accessories.
Numero d'ordine
Contenuto della confezione
26150531JA
12,7 mm
15.000 1/min
2 pezzi
  • Ideal for cleaning, deburring and surface-finishing items made from stainless steel, aluminum, silver, pewter or other white metals
26150532JA
15.000 1/min
3 pezzi
Spazzola in acciaio inossidabile 3,2 mm (532-3) 3 Pz.
  • Per la pulitura di materiali resistenti alla corrosione come acciaio inossidabile ed argento.
12,7 mm
Lunghezza accessori
51,0 mm
Spazzole in acciaio inossidabile
Spazzola a tazza
Uso del perno
Non occorrono perni
15,0 mm
15.000 1/min
15,0 mm
50,0 mm
2
2
8710364070374
26150531JA
Accessorio Dremel Spazzola in acciaio inox 531-2
Dettagli consegna
  • 2 pcs
  • Altezza confezione, 10 cm
  • Larghezza confezione, 5 cm
