Spazzola in ottone 13 mm (536-2) 2 Pz.
Pulitura / Lucidatura
Ideal for cleaning and surface-finishing items made from gold, bronze, copper or brass
  • Use a brass brush to create a soft, satin or matte finish
  • Very effective on flat surfaces and in hard-to-reach areas like slots (brass wire is non-sparking and softer than steel)
Vedi tutte le varianti
Tubi in metallo
Lamiera in acciaio
Ottone
Acciaio temprato
Oro
Alluminio
Argento
Acciaio inox
Ghisa
Rame
Wheel tip for general purpose use. Non-sparking and softer than steel. Will not scratch soft metals like gold, copper, brass. Pack includes two brass brush accessories.
Numero d'ordine
Contenuto della confezione
26150536JA
13,0 mm
15.000 1/min
2 pezzi
  • Ideal for cleaning and surface-finishing items made from gold, bronze, copper or brass
2615000535
19,0 mm
15.000 1/min
1 pezzo
Spazzola in ottone 19 mm (535)
  • Per la pulitura di metalli teneri quali oro, bronzo o rame.
26150537JA
15.000 1/min
3 pezzi
Spazzola in ottone 3,2 mm (537-3) 3 Pz.
13,0 mm
Lunghezza accessori
51,0 mm
Spazzole in ottone
Spazzola a tazza
Uso del perno
Non occorrono perni
15,0 mm
15.000 1/min
15,0 mm
50,0 mm
2
2
8710364070398
26150536JA
Accessorio Dremel Spazzola in ottone 536-2
Dettagli consegna
  • 2 pc
  • Altezza confezione, 10 cm
  • Larghezza confezione, 5 cm
