절단
Drywall Spiral cutting bit (560-3)
신제품
Drywall cutting bit with a specially designed smooth head
The Dremel Drywall Spiral Cutting Bit allows for quick and precise cuts in drywall, saving you time and effort.
It enables cutting straight lines, curved lines, and circles on drywall, catering to various project requirements.
The special designed smooth head prevents accidental cuts into beams behind the drywall and protects loose electrical wires, enhancing safety during the cutting process.
With the Dremel Drywall Spiral Cutting Bit, you can achieve high-quality, seamless cuts that give your projects a polished and professional appearance.
기술적 세부 사항 Drywall Spiral cutting bit (560-3)
드라이월/석고 보드
샹크 직경
작업 직경
작업 길이
30 mm
액세서리 길이
65,0 mm
최대 RPM
35.000 1/분
포장 내용물
3 개
배송 세부 내역: Drywall Spiral cutting bit (560-3)
3x drywall spiral cutting bit
26150560JA
8710364061990
8710364061990
