Lijar
Accesorios para EZ SpeedClic
Discos de lijar DREMEL® EZ Lock (EZ411)
Lijar
Easy to change disks for flat and edge sanding of e.g. wood
Material sándwich
Acero-general
Tubos de metal
Maderas contrachapadas
Latón
Cobre
Aluminio
Tablero de fibra
Laminados
Contrachapado
Aglomerado
rpm
What can you do with it?
Common uses for the Dremel sanding disc include smoothing and shaping wood or removing paint. is great for (smooth) flat and edge sanding of soft materials such as wood and fiberglass Dremel sanding discs have a finer grit than Dremel sanding bands. Also used for rust removal The lower the grit, the more material removal. The EZ411 (grit: 60) and EZ413 (grit: 240) are from the Dremel Exclusive EZ Lock family. This makes accessory changes easy as PULL - TWIST - RELEASE.
How to use?
These discs are best used with the Dremel tool facing towards the work piece, and are flexible to accommodate for any curves on the project. We recommend using mainly the center of the disc for maximum results.
Sanding discs will wear out and are replaceable by removing the mandrel.
Materials to use on
These disks can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 15-20.000 Softwood 15-20.000 Aluminium 15-20.000 Brass 15-20.000 Copper 15-20.000 Plastic 20-25.000
- Easy to change disks for flat and edge sanding of e.g. wood
- Banda de lija de gran tamaño para el lijado de madera y plásticos
- Pequeña banda de lija para el lijado detallado de madera y plásticos
Multiherramientas
- Longitud de la caja del producto, 1.6 cm
- Peso en bruto, 0,01 kg
