Lijar
Oscillating Sandpaper grit 80, 120, 240 (MM80P)
Multi-Max Oscillating Sandpaper, 18 sheets
  • Sandpaper accessory allows the Multi-Max™ to sand paint, varnish, filling compound on a variety of surfaces
  • 80 grit for sanding off paint
  • 120 grit for sanding primer, removing brush strokes and paint runs and drops
  • 240 grit for final sanding of primers before coating
Detalles técnicos de Oscillating Sandpaper grit 80, 120, 240 (MM80P)
Especificaciones técnicas
18 piezas
Detalles de la entrega: Oscillating Sandpaper grit 80, 120, 240 (MM80P)
6 sheets grit 80
6 sheets grit 120
6 sheets grit 240
2615M80PAA
0080596029944
