Multigereedschappen
NIEUW
Multigereedschappen
NIEUW
The Original All-Round Multi-Tool
  • Trusted All-Round Multi‑Tool performance.
  • Curated kit of metalworking essentials for cutting, drilling and precision tasks.
  • Pen‑shaped Flex Shaft Attachment (225) for greater control on detailed work.
99.94 EUR
Limited Metal Edition
Specifically curated, this kit brings together the essentials to create a practical metalwork set up. The kit includes two Metal Cutting Wheels (SC456), a Precision Drill Bit Set (628) that includes 7 high-grade steel bits in various sizes, the Flex Shaft Attachment (225) and a Multi Chuck (4486) for quick and easy accessory changes. The pen shaped Flex Shaft Attachment delivers greater control for detailed tasks, making it easier to work accurately on smaller or more intricate projects.
Dremel 3000 is the true icon of quick, compact and versatile Multi-Tools. Its corded design is built for precision across a wide range of applications, offering variable speed control from 10,000–35,000 RPM for carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. Its soft grip construction reduces vibration for better handling during extended use, and it’s fully compatible with all Dremel Multi Tool accessories and attachments for maximum versatility.
Enter a Versatile Ecosystem
The Dremel 3000 is compatible with the full range of Dremel Multi Tool accessories and attachments. While this edition is designed for metal work, the tool can be easily adapted for variety of tasks by simply changing accessories and attachments. Dremel’s portfolio supports 150+ accessories for a variety of applications: cutting, drilling, engraving, carving, routing, sanding, grinding, sharpening, polishing and cleaning.
Variabele snelheid - 10.000–33.000 omw/min: comfortabeler te hanteren en betere controle.
130 W-motor: voor optimale prestaties.
Softgrip: voor minder trillingen en een betere grip.
Nominaal opgenomen vermogen
130 W
Spanning
0,55 kg
Diepte
Snelheid onbelast
10.000 35.000 t/min
Geluidsdruk
77,1 dB(A)
Geluidsniveau
88,1 dB(A)
Trilling
12,8 m/s²
4053423072938
F0133000VJ
Gebruikershandleidingen
Uw selectie
Dremel 3000 met 6 accessoires
Vergelijken: F0133000JU
EAN-code: 8710364078356
67.95 EUR
Productdetails
Dremel 3000 met 15 accessoires
Vergelijken: F0133000JA
EAN-code: 8710364060856
73.96 EUR
Productdetails
Related Media DREMEL® 3000 Limited Edition 2026
Vergelijken: F0133000WC
EAN-code: 4053423067378
92.95 EUR
Productdetails
Het Dremel 3000 multigereedschap met 1 hulpstuk, 25 accessoires, een gereedschapshouder en een opbergkoffer
Vergelijken: F0133000JP
EAN-code: 8710364074686
95.95 EUR
Productdetails
Dremel 3000 2/25 multigereedschapset uitgestald met verschillende hulpstukken, een flexibele as, een draagtas en enkele accessoires
Vergelijken: F0133000HA
EAN-code: 8710364080823
112.95 EUR
Productdetails
