DREMEL® MAX Diamond Coated Pet Grooming Accessory (416DM)
Diamantbelagt tilbehør for kjæledyrpleie
Accessory For Fast and Comfortable Pet Grooming.
  • Ideal for trimming pet nails.
  • Engineered to accommodate a wide range of dog nail sizes.
  • Faster grooming process and enhanced handling comfort.
  • Compatible with all Dremel Multi-Tools, but recommended for optimal use with the Dremel 7350.
What can you do with it?
Tougher than standard Dremel sanding bands, the diamond-coated pet accessory is designed for use on pet nails. Its innovative channel design not only speeds up the grooming process but also enhances handling comfort, making the experience stress-free for both you and your pet. The accessory's 16 mm drum shape is versatile enough to accommodate a wide range of pet nail sizes, ensuring a perfect fit for almost any pet.
How to use?
Attach the bit and guard to your Multi-Tool. By sanding away the nail bit-by-bit, you are less likely to cut the quick of the nail.
Recommended Speed:
5.000 RPM – 12.000 RPM
416DM slipetilbehør for kjæledyr på hvit bakgrunn.
Leveringsinformasjon
