Boring
DREMEL® MAX Precision Drill Bit set (628DM)
Boring
7-piece highly durable drill bit set in various sizes.
- 7-piece titanium-coated drill bit set in various sizes.
- Built for durability, made of high-grade stainless steel.
- Includes a case container to keep your bits organized.
- Variety in sizes ranging from 0.8mm to 3.2mm.
What you can do with it?
A handy addition to your Dremel toolbox, this titanium-coated Drill Bit Set includes 7 drill bits with a case container to keep bits organized. The bits are ideal for drilling into wood, plastics, soft metals, and drywall. Made of high-grade stainless steel with deep threads and a titanium coating, these drill bits are built for durability. The bits range in sizes from 0.8mm to 3.2mm.
How to use?
Pick the right size for your project. Use the tip of the drill bit to go into the material straight at a 90° angle. All bits have the same 3.2mm shank diameter size, eliminating the need for different mandrels / collets and ensuring faster accessory changes.
Materials to use on:
Can be used on wood, plastics, soft metals and drywall.
Recommended Speed:
20.000 - 30.000 RPM
- 7-piece highly durable drill bit set in various sizes.
- Sett med 4 borbits for boring i tre
- 7-piece titanium-coated drill bits (0,8mm to 3,2mm)
- Lengde på produktesken, 5 cm
- Bredde på produktesken, 1.6 cm
