Reinigen / Polieren
Messingbürste 19 mm (535-2) 2 Stück
Reinigen / Polieren
For cleaning soft metals like gold, bronze or copper.
  • Ideal for cleaning and surface-finishing
  • Use on items made from gold, bronze, copper or brass
  • Use a brass brush to create a soft, satin or matte finish
8.48 EUR
Metallrohre
Blech
Weichmetall
Messing
Gehärteter Stahl
Gold
Silber
Edelstahl
Gusseisen
Kupfer
1/min
Perfect for cleaning flat surfaces and getting into hard-to-reach places, the versatile 3/4 In. (19.1 mm) diameter Brass Brushes are ideal for cleaning and surface polishing to create a soft, satin or matte finish. Non-sparking and softer than steel, the brushes are ideal for use on soft metals like gold, bronze, copper or brass. For optimal results, operate the brush at a maximum speed of 15,000 rpm and avoid applying excessive pressure to extend the accessory’s lifespan and performance.
Schaftdurchmesser
Arbeitsdurchmesser
19,0 mm
Zubehörlänge
44,0 mm
Messingbürsten
Form
Radialbürste
Dornverwendung
19,0 mm
Höchstdrehzahl
15.000 1/min
19,0 mm
Höhe
44,0 mm
2
2
Passende Dremel Geräte
Multifunktionswerkzeuge
Dremel Stylo+ (2050-15)
Heimwerken
26150535JA
Dremel Zubehör Messingbürste 535-2
Lieferdetails
  • 2
  • Länge des Produktkartons, 1.3 cm
8.48 EUR
