Power Carving
Ball Nose Power carving bit DREMEL® MAX (9954)
Power Carving
Ball-nosed shaped carving bit offering 2X faster material removal speed.
- 2X faster material removal.
- Excels at aggressive carving and swift material removal.
- Durable and rust resistant.
What can you do with it?
Sculpting with the Dremel 9954 is a breeze. Compared to standard Dremel carving bits, this one offers a remarkable 2X faster material removal speed. Thanks to its robust stainless steel teeth, it excels at aggressive carving and swift material removal while resisting rust. The 7.9 mm wide ball nose shape is perfect for crafting intricate, rounded shapes, and when you use the accessory's side, you can even tackle larger flat surfaces and create undercuts. Please be aware that this accessory is not compatible with Stylo+, Dremel Lite and Dremel 7350.
How to use?
Allow your accessory and Dremel Multi-Tool to handle the task without excessive force. For best results, use the sides of the accessory head at an angle less than 90 degrees. If you notice excessive chatter instead of material removal, increase the RPM for a smoother outcome.
Materials to use on
Suitable for use on wood, wood-like materials, plastic, EVA Foam and Rubber.
Recommended speed
Wood: 20.000 – 25.000 RPM Plastic: 15.000 – 25.000 RPM
- Ball-nosed shaped carving bit offering 2X faster material removal speed.
Ball Shape Power Carving bit DREMEL® MAX (9951)
- A ball-shaped carving bit offering 2X faster material removal.
Small Taper Power carving bit DREMEL® MAX (9952)
- A wide small taper-shaped carving bit offering a 2X faster material removal.
Flame Power carving bit DREMEL® MAX (9953)
- A wide flame-shaped carving bit offering 2X faster material removal.
- 1 Accessory
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.5 cm
- Gross weight, 0.02 kg
