Power Carving
Ball Shape Power Carving bit DREMEL® MAX (9951)
Power Carving
A ball-shaped carving bit offering 2X faster material removal.
- 2X faster material removal. .
- Excels at both aggressive material removal and effortless smoothing.
- Durable and rust resistant.
What can you do with it?
Introducing the Dremel 9951 - your new power carving essential. This power carving bit is engineered to remove material 2X faster than standard Dremel carving bits, providing a noticeable difference in performance. This bit excels at both aggressive material removal and effortless smoothing, leaving your workpiece ready for the final touch-up with ease. Crafted with durable, rust-resistant stainless steel teeth, the Dremel 9951 can tackle even the toughest carving jobs. Its 9mm diameter ball shape allows you to carve undercuts and shape concave surfaces with precision. Upgrade your carving game today with the Dremel 9951!
How to use?
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. It is not recommended to be used with Stylo+, Dremel Lite and Dremel 7350.
Materials to use on
Suitable for use on wood, wood-like materials, plastic, EVA Foam and Rubber.
Recommended speed
Wood: 20.000 – 25.000 RPM Plastic: 15.000 – 25.000 RPM
- 1 Accessory
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.5 cm
- Gross weight, 0.01 kg
