Printers
DREMEL® 3D Nylon Filament Black 500gr (DF45-NYP-B)
Dremel Nylon filament has been specifically engineered for optimal printing with your Dremel 3D Printer 3D45.
  • RFID filament recognition tag - Printer automatically adjusts settings by reading the filament RFID tag
  • Provides a very smooth surface for strong and flexible prints with heavy wear resistance
Nylon is a synthetic polymer that softens and melts when it’s heated, building your designs strand by strand and layer by layer. With its RFID recognition tag the Nylon filament has been designed to automatically adjusts the Dremel 3D printer settings by reading the filament RFID tag and ensure a stable, strong object with a high quality finish. The Dremel 3D printer melts and prints the 1.75mm Nylon filament layer by layer no thicker than a sheet of paper to provide a very smooth surface for your creation. Perfect for printing strong and flexible 3D objects or prototypes with heavy wear resistance.
Technical details for DREMEL® 3D Nylon Filament Black 500gr (DF45-NYP-B)
Technical specifications
Weight
0.5 kg
Nylon - Only use with DREMEL® DigiLab 3D Printer 3D45
Material Diameter
1.75 mm
Filament length
195 m
180,0 mm
180,0 mm
Height
54,0 mm
Suitable Dremel devices
2615BP45JB
8710364080366
Variations
Similar Accessories (12)
Delivery details: DREMEL® 3D Nylon Filament Black 500gr (DF45-NYP-B)
1x DREMEL® 3D Nylon Filament Black
Product box length, 18.5 cm
Product box height, 18.5 cm
Product box width, 6 cm
Gross weight, 0,80 kg
2615BP45JB
8710364080366
Recommended products:
£1,600.00* RRP incl. VAT
