Printers
DREMEL® 3D20 Idea Builder (3D20-01)
The 3D printer that gets your creative brain running at full steam
This kit includes everything for you to get started with creating your 3D models. Including the Dremel 3D Idea Builder, 1 role of white PLA filament and a quick start guide it will get you building in seconds.
Example of usage
Technical details for DREMEL® 3D20 Idea Builder (3D20-01)
Technical specifications
Voltage
Weight
8,85 kg
Height
40 cm
48.5 cm
Depth
33.5 cm
Extruder
Single Extrusion
Extruder temperature
Up to 230 ℃
Operating interface
3.5” full color IPS touch screen
Max build volume
22.8 cm x 14.9 cm x 13.9 cm
Layer thickness
0.1mm / 100 microns
Filament
PLA
Build platform
Plexiglass
SD-Card
up to 32GB in size
Internal storage
4 GB
Material diameter
1.75 mm
Filament length
162 m
Delivery details: DREMEL® 3D20 Idea Builder (3D20-01)
Dremel® Idea Builder
1x DREMEL® 3D Filament White (DF01)
1x USB Cable
1x SD Card
1x Power Cable
1x Spool Lock
1x Object Removal Tool
1x Instruction Manual
1x Quick Start Guide
2x Build Tape
1x Cleaning Tool
1x Levelling Sheet
Product box length, 58 cm
Product box height, 48.3 cm
Product box width, 43 cm
Gross weight, 15,10 kg
F0133D20JB
8710364075645
Recommended products:
DREMEL® DigiLab 3D Printer 3D40
£1,150.00* RRP incl. VAT
Manuals
Download User manual
