Attachments to Control
Dremel (550(1))
Clear and simple solution for redirecting debris and sparks
Deflects debris and sparks away without interfering with the task at hand.
Deflects debris for various applications, including cutting, sanding, grinding, and polishing.
Suitable for both right- or left-hand grip positions.
The shield is clear to provide a clear view of the work piece.
360 degrees adjustable, provides easy access to the accessory without interfering with the workpiece.
Contents: 1x Comfort guard, 1x carbon steel brush (428), 1x Grinding Stone (8193), 1x SpeedClic Mandrel (SC402), 1x SC metal cutting disc (SC456)
£16.00*
RRP incl. VAT
What can you do with it?
Sparks and debris can be a hazard when using you Multi-tool. This attachment will redirect debris and sparks away from you and create a more comfortable working environment. Comfort Guard attachment does not interfere with the workpiece due to its compact size. It is easy to adjust to your grip position. You can use this attachment for cutting, sanding, grinding, and polishing.
How to use?
Simply screw on to your Dremel Multi-Tool, find your grip position, adjust the attachment and start tackling your project.
Example of usage
Technical details for DREMEL® Comfort Guard (550(1))
Technical specifications
55 cm
Delivery details: DREMEL® Comfort Guard (550(1))
Shield attachment
1 mandrel SC402
1 metal cutting disk SC456
1 grinding stone 8193
1 steel wire brush 428
26150550JB
8710364083008
8710364083008
