Printers
DREMEL® DigiLab 3D Printer 3D40 FLEX (3D40FLX01)
The 3D printer that provides you what you really need - efficiency, high quality and easy print removal.
Easy, safe removal of 3D printed models due to flexible metal build plate
Maximise utilisation of the machine: Draft mode printing profile allows to print up to 30% faster than low resolution
Better print results: more intricate and detailed designs with the improved 50 micron ultra high print resolution combined with guided 2-point semi automated leveling
Optimal safety and less chance for warping of large objects thanks to fully enclosed sturdy plastic design with a 254 x 152 x 170 mm build volume
No installation needed: Fast out of the box use thanks to the easy setup supported by the user-friendly touchscreen control center on the hardware
£1,270.00*
RRP incl. VAT
Designed for a truly seamless 3D printing experience, the 3D40 FLEX offers a variety of features that make it quick and safe to create a range of prints where ease of use really matters, e.g. in classroom. Most notably, the 3D40 FLEX includes a flexible build plate to help make it much easier to remove parts after printing – one of the biggest challenges with most 3D printers today.
Example of usage
Technical details for DREMEL® DigiLab 3D Printer 3D40 FLEX (3D40FLX01)
Technical specifications
Voltage
Weight
16,00 kg
Height
40.6 cm
51.5 cm
Depth
40 cm
Extruder
Single Extrusion
Extruder temperature
Up to 230 ℃
Operating interface
3.5” full color IPS touch screen
Max build volume
25.4cm x 15.2cm x 17.0 cm
Layer thickness
0.05mm / 50 microns
Filament
PLA
Build platform
Flexible Build Plate
Internal storage
4 GB
Material diameter
1.75 mm
Delivery details: DREMEL® DigiLab 3D Printer 3D40 FLEX (3D40FLX01)
Dremel® DigiLab 3D Printer 3D40 FLEX
1x DREMEL® 3D Filament White (DF01)
1 x Flexible Build Plate
1 x USB Cable
1 x USB Flash Drive with Slicing Software
1 x Power Cable
1 x Object Removal Tool
2 x Build Tape
1 x Cleaning Tool
F0133D40JE
8710364081370
8710364081370
