DREMEL® EZ SpeedClic: Pet Nail Grooming Discs (SD60-PGK-1)
£12.00*incl. VAT
NOT SELLABLE
Sanding
Retired Products
DREMEL® EZ SpeedClic: Sanding Discs
NOT SELLABLE
Sanding
Retired Products
What can you do with it?Combined with the Dremel 7020 pet nail grooming tool these sanding discs can be used for safe and stress-free nail filing of your pet’s nails. The discs have a grit of 60, making them the perfect accessory for gradually sanding away the nail.How to use?The accessories can be attached to the EZ SpeedClic mandrel up to 6 times faster, which allows you to change accessories as quickly as pull – twist – release. By gradually sanding away the nail bit-by-bit, you are less likely to cut the quick, which causes the nail to bleed. Materials to use onUse it on your pet’s nails.
  • A safe and stress-free nail trimming experience for your pet.
  • Quickly change accessories by pulling – twisting – releasing the accessory with the EZ SpeedClic system.
  • The pet nail grooming sanding discs have a grit of 60, making them the perfect accessory for gradually sanding away the nail to prevent bleeding.
£12.00*
How to use?
Materials to use on
22,0 mm
Shape
Disc
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Sandpaper with Silicon Carbide Abrasive
0000000000000
F1300000ZZ
Dremel accessory SC411_EZ SpeedClic SANDING DISC
