Retired Products
Dremel (MM722)
Flat Cutting Blades are used for general straight cutting of a variety of materials. These blades can be used only with the MM720 Multi-Flex.
Technical details for DREMEL® Multi-Max Flat Cutting Blades (MM722)
- Chipboard
- Fiberboard
- Hardwood
- Plywood
- Softwood
- Plastic
- Drywall/Plasterboard
- Laminates
- Copper
Technical specifications
Working length
50 mm
Delivery details: DREMEL® Multi-Max Flat Cutting Blades (MM722)
Product box length, 1.8 cm
Product box height, 14.1 cm
Product box width, 5 cm
2615M722JA
8710364056033
8710364056033
