Carving/Engraving/Routing
DREMEL® TRIO Corner Rounding Routing Bit (TR615)
Dremel TRIO Corner Rounding Routing Bit for routing in wood and other soft materials.Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO Corner Rounding Routing Bit (TR615)
Hardwood
Softwood
Rubber
Plastic
Plexiglass
Carbon
Technical specifications
Shank diameter
4,8 mm
Working diameter
9,5 mm
Package Contents
1 piece
Delivery details: DREMEL® TRIO Corner Rounding Routing Bit (TR615)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
2615T615JA
8710364053742
8710364053742
