Cutting
Drywall Spiral cutting bit (560-3) 3 pieces
Cutting
Drywall cutting bit with a specially designed smooth head
  • The Dremel Drywall Spiral Cutting Bit allows for quick and precise cuts in drywall, saving you time and effort.
  • It enables cutting straight lines, curved lines, and circles on drywall, catering to various project requirements.
  • The special designed smooth head prevents accidental cuts into beams behind the drywall and protects loose electrical wires, enhancing safety during the cutting process.
See all variations
13.8 GBP
Drywall/Plasterboard
What can you do with it?
The Dremel Drywall Spiral Cutting Bit is specifically designed for cutting drywall, making it ideal for various applications such as creating openings for electrical boxes, air vents, and other wall features. It enables fast and clean cuts, allowing you to achieve professional results with ease. Additionally, its versatile design allows you to cut straight lines, curved lines, and create precise circles on drywall. Safety is our utmost priority, which is why our drywall cutting bit features a special designed smooth head. This ingenious design ensures that you won't accidentally cut into beams behind the drywall, preserving the structural integrity of your walls. Moreover, it eliminates the risk of harming loose electrical wires concealed behind the drywall, providing you with peace of mind throughout your project.
How to use?
We recommend using a (two-handed) golf grip when using this accessory. Let the accessory do the work without putting too much pressure on it or exceeding the maximum RPM to have the accessory last as long as possible.
Advised Attachment
Dremel multipurpose cutting (565) Dremel line- and circle cutter (678)
Materials to use on
This accessory is only for drywall
Recommended speed
15.000 – 25.000
Working diameter
Package contents
Price
26150560JA
3.2 mm
3 pieces
£13.50*
  • Drywall cutting bit with a specially designed smooth head
2615056032
3.2 mm
1 piece
Spiral Cutting Bit (560)
26150561JA
3.2 mm
3 pieces
£13.50*
Spiral Cutting Bits Multipurpose (561-3) 3 pieces
  • For 'free' cutting in softer materials like soft wood, drywall and plastics
2615056232
3.2 mm
1 piece
£18.50*
Spiral Cutting Bits (562)
  • For 'free' cutting in wall tiles (not floor tiles)
Shank diameter
3.2 mm
Working diameter
3.2 mm
Working length
30 mm
Accessory length
65.0 mm
Maximum RPM
35,000 1/min
3
3
8710364061990
26150560JA
A 560-3 cutting accessory on a white background
Delivery details
  • 3x drywall spiral cutting bit
13.8 GBP
