Sanding
EZ SpeedClic Sanding Discs DREMEL® MAX (SC411DM)
Sanding
20Xlonger life 3-piece sanding discs set.
  • 3-piece set of 60 grit sanding discs.
  • Suitable for use on various materials from wood to metal.
  • 20X longer lifespan compared to Dremel SC411.
See all variations
12.2 GBP
What can you do with it?
Meet the SC411DM – it's a game-changer with a remarkable 20X longer lifespan compared to Dremel SC411, taking your crafting to new heights. This set includes three 60 grit sanding discs, perfect for shaping and smoothing a variety of materials. Thanks to its durable abrasive, the accessory lasts longer, and the polyester cloth backing pad adds strength. With a 38mm diameter and a sturdy metal support, these discs are built to last. Plus, they work seamlessly with the EZ Lock system for quick and easy accessory changes. And, thanks to the patented EZ SpeedClic™ mandrel design, changing accessories is a breeze, happening 6X faster.
How to use?
To use these discs, pair them with the SC402 Mandrel. Dremel's exclusive Easy SpeedClic (SC) system simplifies wheel changes – just PULL, TWIST, and RELEASE. It's 6X faster than a standard mandrel (EZ SpeedClic mandrel SC402 available separately). When using these discs, ensure your Dremel tool faces the workpiece. They're flexible, so they adapt to project curves. For the best results, focus on the disc's center.
Materials to use on
Suitable for use on wood, wood-like materials, plastic, metals, drywall, soft stone and shell.
Recommended speed
Wood: 15.000 – 20. 000 RPM Plastic: 15.000 – 25.000 RPM Metal: 15.000 – 25.000 RPM Soft Stone & Shell – 15.000 – 25.000 RPM Drywall – 15.000 – 20.000 RPM
Working diameter
Grit
Package contents
Price
2615S411DM
38.0 mm
1 piece
£12.00*
  • 20Xlonger life 3-piece sanding discs set.
2615041132
19.0 mm
36 pieces
Sanding Disc 180 grit (411) 36 pieces
  • For (smooth) flat and edge sanding of soft materials such as wood or rust removal
2615041332
19.0 mm
36 pieces
Sanding Disc 240 grit (413) 36 pieces
Working diameter
38.0 mm
304 Stainless Steel
Shape
Disc
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Grit
60
8710364083244
2615S411DM
3 piece of Dremel sanding accessories SC411DM.
Delivery details
  • 3 Accessories
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.5 cm
  • Gross weight, 0.02 kg
12.2 GBP
