Power Carving
Flame Power carving bit DREMEL® MAX (9953)
Power Carving
A wide flame-shaped carving bit offering 2X faster material removal.
- 2X faster material removal. Enables concave and V-Cuts. Durable and rust resistant. Suitable for detailed profile carving and grooving.
What can you do with it?
Experience effortless carving with the Dremel 9953. Enjoy a material removal speed that's 2X faster when using this bit, a significant improvement over standard Dremel carving bits. Its hardened stainless steel teeth provide aggressive carving and efficient material removal while resisting rust and corrosion. The 9.5mm wide flame shape enables concave and V-Cuts, as well as grooving and detailed profile carving. Please note that this accessory is not compatible with Stylo+, Dremel Lite and Dremel 7350.
How to use?
Allow the accessory and your Dremel Multi-Tool to do the heavy lifting, avoiding excessive force. For optimal results, use the sides of the accessory head at an angle less than 90 degrees. If you notice excessive chatter without material removal, increase the RPM for a smoother outcome.
Materials to use on
Suitable for use on wood, wood-like materials, plastic, EVA Foam and Rubber.
Recommended speed
Wood: 20.000 – 25.000 RPM Plastic: 15.000 – 25.000 RPM
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.5 cm
- Gross weight, 0.02 kg
