Power Carving
Small Taper Power carving bit DREMEL® MAX (9952)
Power Carving
A wide small taper-shaped carving bit offering a 2X faster material removal.
- 2X faster material removal.
- Excels at both aggressive carving and smoothing the workpiece.
- Durable and rust resistant.
What can you do with it?
The Dremel 9952's power carving bit is engineered to rapidly remove material 2X faster compared to the standard Dremel carving bits. It can both aggressively remove material and smooth the workpiece to a finish ready for final sanding. The power carving bit's hardened stainless steel teeth allow for aggressive carving and high material removal rates while providing resistance to rust and corrosion. The 6.35 mm wide small taper shape allows for accessibility into hard-to-reach areas and carving deep holes into your workpiece. Thin and accurate lines can be carved with the tip as well. It is not recommended to be used with with Stylo+ or Dremel Lite.
How to use?
Achieve optimal performance with your Dremel Multi-Tool accessory by letting it do the heavy lifting without applying excessive force. To ensure effectiveness, employ the sides of the accessory head at an angle less than 90 degrees. If you notice excessive chatter without material removal, consider increasing the RPM for a smoother outcome. Please note that this accessory is not suitable for use with Stylo+, Dremel Lite and Dremel 7350.
Materials to use on
Suitable for use on wood, wood-like materials, plastic, EVA Foam and Rubber.
Recommended speed
Wood: 20.000 – 25.000 RPM Plastic: 15.000 – 25.000 RPM
- 1 Accessory
- Product box length, 10 cm
- Product box height, 5 cm
- Product box width, 1.5 cm
- Gross weight, 0.02 kg
