Retired Products
Retired Products
Multi-Tool – Precise. Compact. Easy-to-use.
  • Two-speed simplicity: easy to handle when you’re new to DIY’ing
  • Endless uses: Engrave, carve, polish, clean, rout, cut, sand, grind and sharpen with just one tool
  • Get into tight spaces easily
38.25 GBP
The Dremel 200-series is the ideal Multi-Tool to get started with Dremel. It's easy and comfortable the use and offers trusted Dremel quality and reliability at an affordable pricepoint. The tool is compatible with all accessories and attachments, and with the enclosed accessories for sanding, metal cutting and grinding the user can start working with Dremel immediately.
Rated power input
125 W
Voltage
Weight
0.55 kg
18.5 cm
Depth
No load speed
15.000 - 35.000 1/min
Battery technology
No load speed (3)
Speed setting
Dual Speed
Accessory quick change system
No
Sound pressure
74,5 dB(A)
Sound power
85,5 dB(A)
Vibration
3,8 - 5,1 m/s²
8710364049684
F0130200JB
User Manuals
Dremel Multi-Tool 200 series with 5 accessories
Delivery details
  • Dremel 200 Series
  • 5 high quality Dremel accessories
  • Instruction manual
  • Product box length, 7.7 cm
  • Product box height, 25 cm
  • Product box width, 15.6 cm
  • Gross weight, 0.92 kg
38.25 GBP
