Retired Products
DREMEL® Multi-Max 60 Grit Diamond Paper (MM900)
Retired Products
51.49 GBP
Diamond paper accessory for grinding cement, plaster or thin-set mortar. Requires MM11 or MM14 Hook and Loop Pad accessory. For rough grinding, shaping and smoothing of masonry, stone, cement and mortar.
Grit
60
Suitable Dremel devices
Retired Products
8710364055296
2615M900JA
Delivery details
  • Product box length, 1 cm
  • Product box height, 14 cm
  • Product box width, 10 cm
51.49 GBP
