Retired Products
Oscillating Sandpaper
DREMEL® Multi-Max Quick Fit Hook and Loop Pad (MM14)
Retired Products
The Quick Fit Hook & Loop Pad accessory allows Multi-Max oscillating tools to accept sand papers and diamond paper.
- Universal dual interface directly fits all oscillating tools without the use of an adapter, *excluding StarLock
- Compatible with Dremel, Bosch, Makita, Milwaukee, Rockwell, DeWalt, Fein, Porter Cable, Ridgid
- Allows fast accessory changes
Hardwood
Laminates
Chipboard
Stainless Steel
Hardened Steel
Soft Metal
Plastic
DREMEL® Multi-Max Sanding Paper for Paint (P80, P120 and P240) (MM70P) 6 pieces
DREMEL® Multi-Max Sanding Paper for Wood (P60, P120 and P240) (MM70W) 6 pieces
Suitable Dremel devices
Retired Products
- Product box length, 2.5 cm
- Product box height, 14.1 cm
- Product box width, 10 cm
- Gross weight, 0.53 kg
