Retired Products
Oscillating Sandpaper
DREMEL® Multi-Max Sanding Paper for Wood (P60, P120 and P240) (MM70W) 6 pieces
Retired Products
Sand paper accessory for sanding hardwood, softwood, chipboard, rusted metal, fibreglass and plastics. Requires MM11 or MM14 Hook and Loop Pad accessory.
- Sandpaper accessory allows the Multi-Max™ to sand wood, metal, plaster and a variety of other surfaces
- Use 60 grit for rough wood or metal sanding, and rust or old finish removal
- Use 120 grit for general wood or metal sanding
Chipboard
Hardwood
Laminates
Hardened Steel
Soft Metal
Stainless Steel
Plastic
DREMEL® Multi-Max Quick Fit Hook and Loop Pad (MM14)
DREMEL® Multi-Max Sanding Paper for Paint (P80, P120 and P240) (MM70P) 6 pieces
Suitable Dremel devices
Retired Products
- Product box length, 0 cm
- Product box height, 14 cm
- Product box width, 10 cm
- Gross weight, 0.04 kg
