Retired Products
Cutting Blades
DREMEL® Multi-Max Wood and Drywall Saw Blade (MM450)
Retired Products
Cutting Blades
Wood & Drywall Saw Blades are ideal for making precise cuts in wood, plaster and drywall material.
  • Cut openings for venting, electric boxes and damaged flooring areas
  • The blade can also be used for window restoration to remove glazing
  • Ideal for making precise cuts in wood and drywall material
See all variations
13.23 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Chipboard
Fiberboard
Hardwood
Plywood
Softwood
Plastic
Laminates
Drywall/Plasterboard
Working diameter
Package contents
2615M450JA
75.0 mm
1 piece
2615M430JA
1 piece
DREMEL® Multi-Max Multi-Knife (MM430)
2615M435JA
1 piece
DREMEL® Multi-Max Jab Saw Blade (MM435)
2615M482JA
32.0 mm
1 piece
DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM482)
Working diameter
75.0 mm
Suitable Dremel devices
Retired Products
8710364055265
2615M450JA
Delivery details
  • Product box length, 0 cm
  • Product box height, 14 cm
  • Product box width, 10 cm
  • Gross weight, 0.03 kg
13.23 GBP
