Carving / Engraving
Tungsten Carbide Carving bit DREMEL® MAX (9903DM)
Carving / Engraving
Cylindrical-shaped Dremel Max Tungsten Carbide carving bit with round tip
  • Tungsten Carbide carving accessory providing maximum durability and lasting performance
  • Made out of hardened steel and coated with Titanium Nitride to last 2 times longer than the standard bit
  • Use for more aggressive applications to shape, smooth, or grind hard materials
See all variations
19.2 GBP
Carbon
Leather
Rubber
Drywall/Plasterboard
Brick
Brass
Soft Metal
Softwood
Ceramic
Hardwood
Hardened Steel
Stainless Steel
Cast iron
Plastic
The Dremel® Max accessory line, designed by our engineers, provides maximum durability and lasting performance. The heavy-duty Dremel Max Tungsten Carbide Carving Bit 9903DM is coated in Titanium Nitride to last 2 times longer than the standard, non-coated accessory and removes 20% more material than the standard 9903.
What can you do with it?
The extra strong bit is made out of Hardened Steel (HSS) and is coated in Titanium Nitride (TiN) to take on your demanding functional or creative DIY projects that require precision. The 3.2 mm accessory can be used for more aggressive applications to shape, smooth, or grind hard materials such as metals, hardened steel, fire ceramics, cast iron, plastics, and hard woods. The carving bit works well for projects like metal or glass engraving, stone carving, or removing flash from castings. The cylinder shape of the carving bit allows for deep removal of material, cutting flat areas, rounding edges as well as making stop cuts and V-cuts. The accessory tip makes round bottom slots and grooves, round side cuts and V-cuts when held at 45-degrees.
How to use
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. Have a look at the icon or the video to check out the result first, or grab a piece of scrap material before diving into your DIY project Expand your possibilities with these attachments: Flexible Shaft (225); Flex-Shaft Tool Holder (2222); Detailer's Grip Attachment (577); Multi-Vise (2500)
Recommended speed (RPM):
Hardwood 18-24.000 Softwood 25-35.000 Aluminium/brass 12-17.000 Shell/stone 18-24.000 Ceramic: 18-35.000 Plastic 9-11.000 Steel 25-35.000 Ceramic 18-35.000
Shank diameter
Working diameter
Accessory length
Package contents
Price
26159903DM
3.2 mm
39.0 mm
1 piece
£19.00*
  • Cylindrical-shaped Dremel Max Tungsten Carbide carving bit with round tip
2615990532
3.2 mm
38.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter ball tip 3,2 mm (9905)
  • Ball shaped bit, one of Dremel's toughest engraving/carving bits.
2615990332
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter pointed tip 3,2 mm (9903)
  • Cylindrical shaped bit with round tip. One of Dremel's toughest engraving/carving bits.
2615991032
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter spear tip 3,2 mm (9910)
  • Cone shaped point bit, one of Dremel's toughest engraving/carving bits.
2615990132
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter square tip 3,2 mm (9901)
  • Cylindrical shaped bit, One of Dremel's toughest engraving/carving bits
Shank diameter
Working diameter
3.2 mm
Accessory length
39.0 mm
Tungsten Carbide with TIN Coating
Shape
Cylinder
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
39.0 mm
Maximum RPM
35,000 1/min
8710364082773
26159903DM
A 9903DM carving accessory on a white background
Delivery details
  • 1x Dremel® Max Tungsten Carbide Carving Bit 3.2 mm (9903DM)
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
19.2 GBP
