Cleaning/polishing
Versa Bristle Brush (PC364)
The ideal cleaning spin brush for the most aggressive clean-up tasks
Durable nylon bristles for tough and deep scrubbing applications
Threaded shank securely holds the accessory in place
Angled bristles get into tight spaces which allow you to tackle the toughest cleaning tasks
Ideal for grout, tire rims, patio furniture and more
£9.00*
RRP incl. VAT
The Dremel Versa Bristle Brush is ideal for deep cleaning and hard to reach surfaces. With its flexible and yet sturdy nylon bristles, the pads can tackle both indoor and outdoor applications with ease. It is also suitable for use with water or mild cleaning solution as well as car interiors, tires, sports gear and more. Combine the multi-purpose cleaning pad with the Dremel Versa’s high rotation speed scrubbing and the jobs will be completed in no time.
Example of usage
Technical details for Versa Bristle Brush (PC364)
Technical specifications
Working diameter
63,5 mm
63,5 mm
Maximum RPM
2.200 1/min
Package Contents
1 piece
Suitable Dremel devices
2615P364JA
8710364081691
