Versa
Retired Products
DREMEL® Versa (PC10-1/10)
Versa
Retired Products
High Speed Power Cleaner - All your Cleaning Supplies in One
- Multi-purpose cleaner – swap the quick change spin brush or pads to fit your specific cleaning job. From cleaning surfaces that require non-scratch scrubbing, such as pots and pans or sinks, to more aggressive cleaning, like removing burnt-on grease off of a grill or removing soap scum. The best solution for easily scrubbing grime, mold, mildew, grease, soap scum, limescale, bug splatter and tar, gunk, rust and more
- Power scrubber – high rotation speed lets you overcome even the toughest, dirtiest cleaning jobs making it a breeze to clean dirty stove tops, ovens, pots and pans, shower glass, tile grout, drains, sneakers and boots, golf clubs, grills, and more
- Efficient - Powered by USB fast charging Lithium-Ion battery for small, but tough cleaning applications. In addition to all your indoor house cleaning jobs, your outdoor cleaning tasks are swiftly taken care of with this compact, portable cleaning tool. Even on wet surfaces and with or without the use of water or cleaner
Save time with all your difficult cleaning jobs. The Dremel® Versa all-purpose cleaner is perfect for both wet and dry uses, functioning as an oven cleaner, bathroom tile or shower glass cleaner, shoe cleaner and much more. All in one cleaning tool. Whether you’re kitchen cleaning or car detailing, the lightweight and compact design allows you to get into those hard to reach places. Both indoor and outdoor. Thanks to the four quick change spin brush and cleaning pads, including a non-scratch pad and heavy duty pad, this multi-purpose cleaner can be used both on delicate surfaces and on surfaces that allow for more aggressive cleaning. Eliminate elbow grease and effortlessly power clean the toughest surfaces.
The Dremel Versa is waterproof which allows you to tackle both dry and wet cleaning applications.
Easily charge the cordless Dremel Versa with Lithium-Ion battery with the included USB charging cable.
Have perfect control over your cleaning jobs with Dremel Versa’s ergonomic and compact design.
User Manuals
- Versa PC10
- 1x Splash Guard
- 3x Foam Pad
- 3x Non Scratch Pad
- 3x Heavy Duty Pad
- 1x Bristle Brush
- USB Cable
- Zipper Bag
