Versa
Versa Corner Brush (PC369-1)
Versa
This Corner Brush easily cleans hard-to-reach places, corners and edges.
  • The Corner Brush has an ideal size to clean the hard-to-reach areas. Thanks to the hollow centre design you can easily clean corners and edges.
  • Use the Corner Brush on hard surfaces, like tiled walls/floors, granite countertops, plastic, fabrics and metal! Endless versatile cleaning from stoves, motorcycle metal spokes and more.
  • Ready to conquer the cleanup? Simply screw the corner brush onto your Dremel Versa and you’re good to go.
13.5 GBP
From cleaning corners of tiled walls to cleaning the nooks & crannies of metal spokes, the corner brush is ideal for both dry and wet applications. With the hollow centre design, this brush can form a pointing cleaning surface to get into those hard-to-reach places to enable a deep clean. The re-usable and high-quality brush combined with your Dremel ® Versa allows you to do more cleaning in less time and with less effort!
Working diameter
40,0 mm
Accessory length
50,0 mm
40,0 mm
Maximum RPM
2.200 1/min
Height
50,0 mm
Suitable Dremel devices
Versa
DREMEL® Versa (PC10-1/10)
8710364082469
2615P369JA
Dremel Versa accessory  Versa Corner Brush PC369-1
Delivery details
  • 1x PC369
13.5 GBP
