Cleaning/polishing
Versa Kitchen Brush (PC372-1)
The Kitchen Brush is perfect for delicate cleaning without scratches.
The Kitchen Brush is perfect for delicate cleaning, quickly removing food stains without scratching the surface.
Tackle everyday tasks from cleaning most common mugs, glasses and bottles to scrubbing pots, pans and dishes. Clean more with less effort.
With it’s long Nylon bristles it’s easier to deep clean the inside of bottles or deep pots especially when combined with the extension (10cm), hard to reach places will be cleaned with ease.
Ready to conquer the cleanup, simply screw the extension onto your Dremel Versa and screw on the required Kitchen Brush. You’re good to go!
The Kitchen Brush is washable perfect for multiple uses.
£9.00*
RRP incl. VAT
The Dremel Versa Kitchen Brush quickly removes food stains without scratching the surface. With its long-lasting and washable nylon bristles, you can use the Kitchen Brush accessory for many cleaning jobs. Easily reach bottoms of glasses, bottles and mugs for thoroughly cleaning, thanks to the included extension (10cm). The front bristles expand into the bottom of bottles for effective cleaning of internal edges and cover hard-to-reach areas.
Example of usage
Technical details for Versa Kitchen Brush (PC372-1)
Technical specifications
Working diameter
62,0 mm
Working height
100,0 mm
Max working depth
190,0 mm
Maximum RPM
2.200 1/min
Height
100,0 mm
Package Contents
1 piece
Suitable Dremel devices
2615P372JA
8710364082483
