Carving / Engraving
Carving bit DREMEL® MAX (115DM) 2 pieces
Carving / Engraving
Cylindrical-shaped Dremel Max carving bit for wood and more
- Carving accessory with maximum durability and lasting performance for demanding DIY jobs that require precision
- Coated with Titanium Nitride to last 2 times longer than the standard bit
- Remove material with precision for applications like carving, engraving or freehand routing
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
The heavy-duty Dremel Max Carving Bit 115DM is coated in Titanium Nitride to last 2 times longer than the standard, non-coated accessory.
What can you do with it?
Remove material with precision for applications like, carving, freehand routing, shaping and hollowing in a wide range of materials. Ideal for your carving and engraving projects in wood, plastic and soft metals such as aluminium, copper and brass.
How to use:
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. Have a look at the icon or the video to check out the result first, or grab a piece of scrap material before diving into your DIY project. Expand your possibilities with these attachments: Flexible Shaft (225); Flex-Shaft Tool Holder (2222); Detailer's Grip Attachment (577); Multi-Vise (2500)
Recommended speed (RPM):
Aluminium 15-25.000 Brass 15-25.000 Copper 15-25.000 Hardwood 20-30.000 Softwood 20-30.000 Plastic 15-20.000 Steel 15-25.000
- Cylindrical-shaped Dremel Max carving bit for wood and more
High Speed Cutter 3,2 mm (194) 2 pieces
- Medium sized cylindrical shaped head. Shape of e.g. wood.
High Speed Cutter 5,6 mm (196) 2 pieces
High Speed Cutter 6,4 mm (117) 2 pieces
- Carve and engrave in curved and straigh material like wood
High Speed Cutter 6,4 mm (125) 2 pieces
- Largest triangular shaped head. Shape and create V-grooves in e.g. wood.
High Speed Cutter 7,2 mm (134) 2 pieces
- Carve and remove a lot of material like wood
High Speed Cutter 7,8 mm (114) 2 pieces
- Largest ball shaped head. Carve and engrave in e.g. wood
High Speed Cutter 7,8 mm (144) 2 pieces
- 2x Dremel® Max Carving Bit 7.8 mm (115DM)
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 2.5 cm
