Cordless Tools
Multifunctional Butane Soldering Iron – The cordless 6-in-1 gas-torch for hot cutting, pyrography and more
Included 6 accessories allow a variety of creative applications that require precision on different materials: soldering, pyrography, hot cutting, heat embossing, welding and more
Variable temperature setting allows detailed and intricate finishing for your DIY project
Integrated ignition trigger for easy startup - no independent ignition tool required
Child safety lock mechanism prevents accidental release of gas
The Dremel VersaTip is the ideal soldering torch for people engaged in creative and detailed projects that require precision and versatility combined with portability. It comes with 6 interchangeable tips which makes it the perfect butane tool for various heat applications: soldering, heat embossing, hot cutting, welding, pyrography, paint removal and more. The variable temperature setting ensures you maximum flexibility for the magnitude of all applications.
Example of usage
Technical details for DREMEL® VersaTip (2000-6 Hobby)
Technical specifications
Weight
0,135 kg
2.5 cm
Depth
2.5 cm
Battery technology
Ignition
Piëzo
Burn time
90 min
Tank capacity
17ml / 9g
Temperature
1200C (open air) 680C (hot air) 550C (tips)
Precision tip
Dual temperature
Removable cord
Drip control
Overview of prices and delivery details
DREMEL® VersaTip (2000-6)
Order number: F0132000JA
EAN Code: 8710364037582
£40.00
See delivery details
Dremel VersaTip
Soldering Tip
Cutting Knife
Hot Knife
Flat Wide Flame Head
Reflector
Hot Blower Head
Soldering Tin with Blue Cap
Soldering Sponge + sponge box
Instruction manual
Tin storage case
Product box length, 17.8 cm
Product box height, 33.1 cm
Product box width, 5.3 cm
Gross weight, 0,80 kg
Order number: F0132000KA
EAN Code: 8710364046416
£40.00
Dremel VersaTip
Soldering Tip
Cutting Knife
Hot Knife
Reflector
Hot Blower Head
Instruction manual
Tin storage case
Product box length, 18 cm
Product box height, 33 cm
Product box width, 5.7 cm
Gross weight, 0,89 kg
