Butanetools
DREMEL® VersaFlame (2200-4)
Butanetools
Butane torch – The most versatile stationary burner for both DIY and hobby projects
- Included accessories allow a variety of creative applications: soldering, shrinking, welding, etc.
- Integrated ignition button for easy startup, no independent ignition tool required
- Variable temperature and flame control for versatile use in both torch and flame mode
49.48 GBP
The Dremel VersaFlame is the only stationary burner that safely supports open flame use and comes with a catalyst and soldering head, making it the most versatile stationary burner in the market today, especially for DIY applications. The Dremel VersaFlame is powered by liquid butane gas for quick heat-up and fast recharge. Applications for use include: soldering, shrinking, welding, etc.
Tank capacity of 22 grams: Longer use; full tank lasts up to 75 min at maximum capacity
Precise flame: Allows for detailed open flame work
Weight
0,227 kg
17 cm
6 cm
Depth
11 cm
Battery technology
Ignition
Piëzo
Burn time
75 min
Tank capacity
34ml / 20g
Temperature
1200C (open air)680 - 1000C (hot air)550C (tips)
8710364042081
F0132200JA
